Use scripted field in the build-in two dimensional filter results gadget
aligntechsupport June 25, 2020 edited
Hello colleagues,
I recently tried to create scripted ScriptRunner field and use it in the build-in two dimensional filter results gadget. But I can't see the scripted field in field options.
The field has:
Searcher: Free Text Searcher
Template: Text Field (multi-line)
Is there any ways to use scripted ScriptRunner field in build-in JIRA gadgets?
Thanks, Artem, Align Technology.
Hernan Halabi - Elite IT Consulting Group
Hello @aligntechsupport if the field isn't showing it's because it's not supported. I can see that is a text field like. Those never work for those types of  reports, check for summary or description as an example, you won't find them either
Register now
