I use the Scriptrunner Escalation Service to monitor 5 projects for overdue issues.
Then an email should be send to all projectrole members of "QMB" of the project, the issue occurs from.
I have the code to that for one specific project. Within this I use the projectkey to get the users and their mail adresses.
In my mind there needs to be a way for the script to look up the JQL results and only get the users of the QMB-projectrole for this exact issue.
Does anybody had a problem like this before?
My code
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import groovy.transform.BaseScript
import com.atlassian.jira.issue.issuetype.IssueType
import javax.ws.rs.core.Response
import javax.ws.rs.core.MultivaluedMap
import com.atlassian.jira.issue.IssueManager
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.config.IssueTypeManager;
import com.atlassian.jira.issue.link.IssueLink
import com.atlassian.jira.security.roles.ProjectRoleManager
import com.atlassian.mail.Email
import com.atlassian.mail.server.MailServerManager
import com.atlassian.mail.server.SMTPMailServer
import javax.servlet.http.HttpServletRequest;
// Get all the mail addresses from the role members of a project
def projectRoleManager = ComponentAccessor.getComponent(ProjectRoleManager)
def projectRole = projectRoleManager.getProjectRole("QMB")
def project = ComponentAccessor.getProjectManager().getProjectObjByKey("TA")
def usersInRole = projectRoleManager.getProjectRoleActors(projectRole, project).getApplicationUsers()*.emailAddress.join(",")
// Create an email
def emailAddr = usersInRole
def subject = "[Audit]: Measure overdue"
def body = "Hello dear QMB,\nan action is overdue.\nPlease speak to the assignee.\n\nJIRA issue: https://xxx.com/browse/${issue.key} - ${issue.summary}.\n\nBest regards,\nAuditprocess-Workflow\n"
def sendEmail(String emailAddr, String subject, String body) {
SMTPMailServer mailServer = ComponentAccessor.getMailServerManager().getDefaultSMTPMailServer();
if (mailServer) {
Email email = new Email(emailAddr);
email.setSubject(subject);
email.setBody(body);
mailServer.send(email);
} else {
// Problem getting the mail server from JIRA configuration, log this error
sendEmail (emailAddr, subject, body)
Lars
I found a solution.
I get the projectID directly from the issues that comes out of the JQL Query.
// Get all the mail addresses from the role members of the project of the issue
def project = issue.getProjectObject()
So for all that are interested. Here is the complete code
// Create an email
if (mailServer) {
} else {
This looks fine on first look (but the emailAddress csv text might contain ", null" in case one of role actors has no email. The body will I think show up with "\n" in it because it should be sent as plain text I think.
Could you add more logging such as 'log.warn("Sending email to: " + emailAddr)' so we can trace how far and what values the script contains?
There also was a problem at one point with classpath and openjdk - but you should be able to see an exception in atlassian-jira.log that it wasn't able to find class by name or something like that.
I would add a few more log lines and then check atlassian-jira.log to see what's going on.
Hi Radek, I added the log.warn line to the code.
Here ist what the log file comes up with.
2022-02-24 16:09:46,963+0100 http-nio-8080-exec-20873 WARN admin_lokal 969x773824x1 oa312a 192.168.x.x:3676,0:0:0:0:0:0:0:1 /rest/scriptrunner/latest/scheduled-jobs/com.onresolve.scriptrunner.canned.jira.jobs.EscalationService/preview [c.o.scriptrunner.runner.ScriptBindingsManager] Sending email to: user.name@company.de,lars.brozinski@company.de
So everything is fine. Btw. we only have users with email adresses in these roles. So ne "null" problematic shouldnt be a problem.
But how does this brings us forward in my original problem?
