Use validator to prevent creating duplicate sub-task
Mobileye Atlassian Licenses January 9, 2018
I want to use validator of a transition to prevent creating the same sub-task with the same summary.
For that - I'm using the following simple scripted validator:
ScriptRunner workflow function - Simple scripted validator (condition apply).
import com.atlassian.jira.issue.IssueManager
def issueManager = ComponentAccessor.getIssueManager()
Collection subTasks = issue.getSubTaskObjects()
if(issue.isSubTask())
    def issueParent = issue.getParentObject()
    def parentSubTasks = issueParent.getSubTaskObjects()
    def currentSubTaskSummary = issue.getSummary()
    !parentSubTasks.find{it.getSummary() == currentSubTaskSummary}
The problem is that I still see the option to use the transition even though I'm not expecting to see it with this validator.
Any idea?
Bar
Alexey Matveev
January 9, 2018
Validator do not hide transition buttons. They just check the input in the transition screen and can throw an error if the values are wrong.
What you are looking for are conditions not validators
Hi Alexey,
Thanks for your answer.
You are right! I got confused, but when I'm trying to use this script in the Conditions it still let me use the transition.
Do you know why?
Bar
Alexey Matveev
January 9, 2018
Condition must return true or false. Your script does not return anything. Try like this
if(parentSubTasks.find{it.getSummary() == currentSubTaskSummary}) {
return false
} else {
return true
return false
Thank you, but it still let me use the transition.
Alexey Matveev
January 9, 2018
The transition button will be hidden only if your script returns false. Try to put log.error in your code before all return statements and see if your script returns false.
I wrote this code:
import org.apache.log4j.Logger
import org.apache.log4j.Category
def Category log = Category.getInstance("com.onresolve.jira.groovy.Condition")
log.setLevel(org.apache.log4j.Level.DEBUG)
log.info("Sub Task ID List: " + subTasks)
def flag = 0
for (int i=0; i<subTasks.size(); i++) {
def value = subTasks[i] as String
def issueSubTask = issueManager.getIssueObject(value)
if(issueSubTask.getSummary().contains("request")){
log.info("There is a Bundle branch request sub-task")
flag = 1
return false
log.info(flag)
if(flag==0){
return true
Even if I checked that the flag equal to 1 I still can click on this transition.
Do you know why?
Bar
Alexey Matveev
January 9, 2018
Sorry for my mistake. If you want the transition button to be hidden , you should set passesCondition variable to false.
passesCondition = false
And your script should be like this
def flag = 0
flag = 1
log.info(flag)
if(flag==0){
passesCondition = true
Like • Lucas Rodrigues de Oliveira likes this
Thank you so much!
Now it works as expected.
Ryan Bullock September 9, 2019
I have a similar request. I tried the first script but it did not work for me.
I have a post-function that creates a subtask on transition. However, it is possible to go back in the workflow and then complete the transition again, which creates a duplicate sub-task. How can I prevent a duplicate sub-task from creating if the transition/sub-task creation had already previously occurred?
@Alexey Matveev Any suggestions?
