I have a new contractor starting this week. They are to have access to only 1 project in JIRA.
The issue, is that they are seeing 4 other projects in addition to the one I want them to see. I can't seem to figure out why this is. We have a lot of JIRA projects, so I'm finding it odd that there are 4 oddities showing up. For troubleshooting sake, we'll just look at one oddball project (if I get this sorted, I think I can figure out the rest!).
The user is a member of 1 group: ext-project-only
The group has the following global permissions: Browse Users
The group has the following application access: JIRA service desk, JIRA software, JIRA Core
The project I don't want the user to see (we'll call it OOPS), has limited access already. The users, developers, admin roles have limited membership of individuals only (like 5 people). There are no groups being added to a role in the OOPS project.
The OOPS project it's own permission scheme. It too is fairly locked down. All permissions are granted to either users, developers or administrator roles. EXCEPT for one custom field value., "EE Manager" which is a user-picker field. EE Manager is included in the "Browse Projects" permission scheme.
When using the permission helper, the status for the user states "user does not have the "browse projects" permission. There is also a red X status for the Project role (user is not a member of any of these project roles), and a red X for the User Custom Field Value (user is not listed in the EE Manager Field).
However, the summary section shows a green checkmark status for "JIRA service desk does not override this permission." My understanding is that JIRA service desk application permissions do not override the "browse projects" permissions (which are showing as a red X/No).
Why do you think the user is able to browse to the project? Note, they can't see any issues within the project (phew), but I'd like to make the entire project not appear on the list.
Thanks! I'm stumped and probably have looking disease from trying to figure this out today!
So I think I found the answer. I did some trial and error, and have found the "EE Manager" custom field to be the issue.
First, I removed the group from the JIRA Service Desk application access to see if it made a difference. It didn't.
Then, I removed the "EE Manager" field from the Browse Project permission in the permission scheme. Voila, the project is no longer visible to this user.
Apparently, if the custom field is a "user picker" field, because anyone could be in that field, anyone could potentially have access to the project. Fortunately the security scheme prohibits the issues from being visible. I see this as a potentially large security hole.
Yikes. Glad I figured it out, but bummed that we either lose functionality with the project, or just accept that anyone with access to our JIRA server can see a potentially sensitive project exists.
Hi @Jennifer Osborn ,
Understand you solved the problem. I believe this is the case mentioned in https://confluence.atlassian.com/jirakb/granting-browse-project-permission-to-current-assignee-reporter-or-user-custom-field-value-allows-all-users-to-view-project-information-586056400.html?utm_medium=scheduledLogScan&utm_source=STP
Sara
I guess you don't happen to have "Reporter" in your "Browse Project" permission on these 4 projects?
Did you expand the Permisson Helper window to see all the failed results?
HTH,
KGM
Hi KGM!
There's no "Reporter" in the Browse Project permission. For the OOPS project, it's User, Developer, Admin & EE Manager. (and each role has 5 individual people in it, no groups)
For the permission helper, in addition to the "user does not have Browse Projects permission" red X, there are the following when expanding the results:
Red X: Project Role
Red X: User Custom Field Value
Green Check: JIRA Service Desk, with the note: JIRA service desk does not override this permission
