Users of specific group unable to assign issues to users with proper permissions
Bhaskar June 12, 2019 edited
Suddenly users of specific user group not able to assign issues to different users of the project which they could able to do it previously.  Other group users which has "assignable user" as well as "assign issues" still could able to assign.
I have checked the project permissions  has  both "assignable user" as well as "assign issues" permission for project. Users of this group are part of jira-software-users group which has  browser user and group permission
Please advise on what would be my next steps to resolve this.
Ilya Turov
June 12, 2019
you can go to that project's administration page -> Permissions -> Permission helper and try to find out "why a user does or does not have certain permissions"
Bhaskar June 13, 2019
Thanks for your responses. I have checked the permissions(Assignable User and Assign Issues) for the user of that specific user group using the permission helper as suggested.
It says below
<<Specific User>> has the 'Assignable User' permission
<<Specific User>> has the 'Assign Issues' permission
It suggests that <<User>> is not in the jira-administrators group suggesting him to add to that group
My question is, this was working fine a week back and not sure why it is not allowing users to assign now
Appreciate more suggestions.
Bhaskar
Ravi Sagar _Sparxsys_
June 14, 2019
In your Permission Schemes are permissions given to a user, role or a group?
Also check the Global Permissions and check who has "Browse Users".
Ravi
Ilya Turov
June 14, 2019 edited
@Bhaskar
Judging by the fact that it was working fine last week and you didn't change anything in this project, the case might be that this permission scheme is shared between several projects and it was changed for another one without thinking that it might affect the one you are having issues with now.
e: in this case you can check audit logs for this scheme and see if anything was actually changed. Just go to System -> Audit Log and paste your scheme's name into a searchbar.
Bhaskar June 16, 2019 edited
 Appreciate your responses
Ravi,
Permission are given to a role
Users of this group are part of jira-software-users group which has  browser users Global permission
Ilya Turov,
As suggested checked the audit log for the permission schema, there was no changes to permission schema as such
June 12, 2019
Hi @Bhaskar
Use the permission helpertool in Jira, it might give you some insights.
Ravi
