Users unable to open jira Tickets in jira IE8 and IE10?(version jira: 6.0.1)
Suresh
users must use IE in the organization,
They are unable to open the assinged tickets it showing some errors
Please help us to rectify!!
Best Regards
Surehs
David G
Without seeing the error, it most likely is Compatibility Mode. Having Compatibility Mode ON will completely distort the JIRA view, in 6.0 or later, and turn everything into vertical lists and make it unreadable.
The option, "Display intranet sites in Compatibility View" is enabled by default in IE. To disable it, simply open IE, click the Settings cog wheel icon on the right side, and choose Compatibility View Settings. Uncheck the checkbox, hit OK, close your browser and relaunch.
If that resolves your issue, you can set a network rule to disable this on all of your company machines, and then specifically add site domains to the list as needed.
Suresh
error is: yes it is displaying vertical list.Is there any other way to reslove this?
David G
No other work around for it, Compatibility Mode is the culprit and needs to be disabled for your JIRA domain.
Luther Hargrove
February 24, 2014
What is the error?
