Using Custom Fields in automation
Robin Stemmers
Hi All
As a newbie, I am trying to include a variety of custom fields we created into a basic send email automation.
Under Automation on Jira Cloud
Trigger - Approval Completed
Then do this: Send Email to reporter (example - myself)
So the standard variables work
I don't have access to additional tools or plugins
Is there a simple way to pull in this custom field information
Support Team is the field name
The custom ID is 10051
Sample
Result
Bryan Trummer - ReleaseTEAM
Hi Robin,
You may want to try ${issue.customfield_10051}. This may pull that information for you in the email.
Robin Stemmers
Hello Bryan
Thanks for the feedback.  I have tried that before and it didn't work.
I tried it again now - incase i did something wrong - i still don't get the information
it appears as follows in my email
Hi Robin,
Sorry that didn't work. I was hoping that maybe one of those two items would work. It seems that this is something that is not supported at this time from what I can tell.
Robin Stemmers
Hi
Do you have any other suggestions?
As of right now I do not. I will look around and see if I can locate anything else.
Robin Stemmers
Thank you
From my knowledge and what I have seen this doesn't appear capable out of the box in Service Desk Automation. There may be some plugins that have automation in them that could accomplish adding custom fields to an email.
Here is an Atlassian document on Service Desk Automation with some other third party automation tools that may work for you.
https://confluence.atlassian.com/confeval/jira-service-desk-evaluator-resources/jira-service-desk-automation
Lucia Calderon
I use {{issue.fields.customfield_XXXX}} and it works in my automation, I hope it helps.
Like # people like this
NGJ Netrunner
June 13, 2021
Thanks @Lucia Calderon
Solved for me!
KC Wong
When you can only refer to a custom field by its ID (customfield_xxxxx) it becomes a serious problem in both Data Center and Cloud.
Your custom field ID in sandbox will not be the same as the ID when you go create it in production (or between different environments). All your configurations and scripts need very careful manual remapping.
Like Mykenna Cepek likes this
praveen jaiswal December 4, 2023
Jira has support for using custom fields in Automation rules. I had created a custom field QA and I tried trigger of 'Any update of the field' along with action Send email to QA.
It is working nicely. You may wish to google and make the email look better by including URL , issue key etc.
Hope this helps.
Vaibhav.Bali
September 12, 2024
How did you do this?
