I'm using the Filter Results Gadget to show a list of sub-tasks. I would want to include a column that shows the Parent Summary to make know where the sub-tasks came from.
So far, I don't know how to do it. Linked issues are only for links while Sub-tasks only work when your displaying the Parent.
Hi Marc,
Columns in Filter Results gadget represent various fields of the displayed issue. Since parent summary is not a field there is no way to display it.
However, using 3rd party add ons like ScriptRunner or JMCF (free) for example, you can create scripted fields which will contain the current value of a parent's issue 'Summary' field. That way you can display it in your gadget.
