Using JQL queries in ScriptRunner
Thomas Hardin
Good morning,
I'm trying to run a JQL query with ScriptRunner for Jira, however; my queries have some characters that need to be considered. Basically, the queries are focused on a project and 2 fields.
Example:
def query = jqlQueryParser.parseQuery("project = Portfolio and cf[12947] = CareerLink and cf[12946] = 1.2")
When I run the query on a field that has "( ) " in it, the result is "[]"
Example:
def query = jqlQueryParser.parseQuery("project = Portfolio and cf[12947] = WebSites (Core) and cf[12946] = 1.2")
Or, when I have a field that has a "-" in it, I get an error.
Example: def query = jqlQueryParser.parseQuery("project = Portfolio and cf[12947] = Cognos BI - Infrastructure and cf[12946] = 2.6")
Result:
Any suggestions?
Thank you all in advance!
9 votes
Andrey Minov
September 13, 2019 edited
In JIRA 8.x use SearchService instead of SearchProvider
import com.atlassian.jira.bc.issue.search.SearchService
def searchService = ComponentAccessor.getComponent(SearchService.class)
def results = searchService.search(user, query, PagerFilter.getUnlimitedFilter())
results.getResults().each {issue ->
def issue_res = issueManager.getIssueObject(issue.id)
Eric Monfette October 22, 2019
hmm
Eric Monfette October 23, 2019
How can you set date in script and use in query?
laralg
November 14, 2019
@Andrey Minov You just helped me fix a bunch of scripts! Only answer in the whole internet showing this properly!! <3
Like • 2 people like this
Alexey Matveev
June 20, 2018
Your code should be like this:
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.jql.parser.JqlQueryParser;
import com.atlassian.jira.issue.search.SearchProvider;
import com.atlassian.jira.web.bean.PagerFilter;
import com.atlassian.jira.issue.fields.config.FieldConfig
import com.atlassian.jira.issue.context.IssueContextImpl
import com.atlassian.jira.issue.customfields.manager.OptionsManager
import com.atlassian.jira.issue.customfields.option.Options
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
def findIssues(String jqlQuery) {
def issueManager = ComponentAccessor.issueManager
def user = ComponentAccessor.jiraAuthenticationContext.user
def jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class)
def searchProvider = ComponentAccessor.getComponent(SearchProvider.class)
def query = jqlQueryParser.parseQuery(jqlQuery)
def results = searchProvider.search(query, user, PagerFilter.unlimitedFilter)
results.issues.collect {
issue -> issueManager.getIssueObject(issue.id)
def user = ComponentAccessor.jiraAuthenticationContext.userCustomField
cf = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Product Name+")
CustomField cf1 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Product Name+ 2.0")
def jqlQuery = "project = Portfolio and cf[12947] = \"Cognos BI - Infrastructure and cf[12946] = 2.6\""
def issues = findIssues(jqlQuery)
Thomas Hardin
Thank you. Next question. If my intent is to populate the query dynamically with values from the custom fields. Let's say I have:
def project = "Cognos BI - Infrastructure"
def version = "2.6"
Using this for test purposes only. What would the query look like?
Alexey Matveev
June 20, 2018
def jqlQuery = "project = ${issue.getProject()} and cf[12947] = \"Cognos BI - Infrastructure\" and cf[12946] = ${issue.getFixVersions()}"
Thomas Hardin
My apologies @Alexey Matveev, I should have provided a bit more context. What I am doing is using a single project, "Portfolio", where the issue represent other projects and versions. The reason for this is the my management is tracking fund codes. So, What I am doing is setting up some behaviors where given a certain set of values, which are pulled from the 2 custom fields, "Project Name" and "Project Version".
Therefore I need to be able to add the values from those fields into the query. So cf[12947] is "Project" and needs to pull the value from project variable and cf[12946] is "Project Version" and needs to pull the value from version variable.
def jqlQuery = "project = Portfolio and cf[12947] = project variable and cf[12946] = version variable")
I was using def project = "Cognos BI - Infrastructure" and def version = "2.6" so that I could test the script where the values were inserted into the query.
I'm very sorry for any confusion and very much appreciate your assistance.
Alexey Matveev
June 20, 2018
cf = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Project Name")
CustomField cf1 = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Project Version")
def jqlQuery = "project = ${issue.getProject()} and cf[12947] = ${issue.getCustomFieldValue(cf1)} and cf[12946] = ${issue.getCustomFieldValue(cf2)}"
Edward Greathouse January 9, 2019 edited
Retracting previous message.
Eric Monfette October 22, 2019 edited
How can you format query to work with date? ex: created > 2019-07-01. "-" doesn't seem to work
