×I'm currently using JWT Calculated Number Field for getting the resolution time (resolution date - created date)
Now, I'm trying to create several time trackers and would like to ask for help since I can't get it working.
For example, time between created and change status to in progress. Or created to first public comment.
regarding your status changes, the timesOfTransition might help solving your request (see the comprehensive list here: https://apps.decadis.net/display/JWT/Expression+Parser).
An example:
first(timesOfTransition("", "In Progress"))
This expression returns the timestamp when the issue was first transitioned from any status to In Progress.
Regarding your second use case referring to adding a public comment, I'm not aware of any function that is capable of extracting this timestamp. However, I'll try to figure it out and will get back to you here.
Thorsten
Thanks! I've also been experimenting on the fields a bit. And for the number field, when you extract, it would always be in milliseconds. The extract is in csv. Is it possible to make the extract be what the display is or at list convertible into seconds?
so you're trying to export your issue navigator result to *.CSV and receive your durations in pretty short format, e.g. 1d 1h 34m, instead of 920611160000000 ms?
If this value is for reporting purposes mainly, I'd rather suggest using a Calculated Text Field with the following expression:
shortFormatDuration(timeInStatus("Done"))
That way, the display in Jira stays the same, but the *.CSV export will also include the pretty format 1d 1h 34m.
Does this help with your requirement?
so you're trying to export your issue navigator result to *.CSV and receive your durations in pretty short format, e.g. 1d 1h 34m, instead of 920611160000000 ms? >>> On display it would say 1d 1h 34m but on extract it would instead be 920611160000000.
I'll check it out and let you know how it goes. Thanks!
