Using Post function script to Transition Sub-Tasks
pmooresaxton March 2, 2014
Hi All, I am new to groovy so need some advice on the post function scripts.
I would like to use a post script to transition all Sub-taks of the parent.
I found this script to close sub-tasks
https://jamieechlin.atlassian.net/wiki/display/GRV/Post+Functions#PostFunctions-Autocloseallsub-tasks
The question is, apart from the action ID, what else do I need to change to make it specific to my JIRA project?
specifically,
String currentUser = ((WorkflowContext) transientVars.get("context"))
Do I need to change "Context" to something more specific
workflowTransitionUtil.setIssue(it);
Do I need to change "it" to the issuetype of the subtask?
Also, Do I need to call a package (e.g. package com.onresolve.jira.groovy.canned.CannedScript) before running the script?
I am using the Post Function "Script Post-Function" -> Script file, using the absoulte file path.
I'm running JIRA v5.2.4 with Script Runner 2.1.12
This is what I have in the file, but at the moment it is not working....
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.comments.CommentManager
import com.opensymphony.workflow.WorkflowContext
import org.apache.log4j.Category
import com.atlassian.jira.config.SubTaskManager
import com.atlassian.jira.workflow.WorkflowTransitionUtil;
import com.atlassian.jira.workflow.WorkflowTransitionUtilImpl;
import com.atlassian.jira.util.JiraUtils;
log = Category.getInstance("com.onresolve.jira.groovy.AutoTransitionChildIssues")
String currentUser = ((WorkflowContext) transientVars.get("context")).getCaller();
WorkflowTransitionUtil workflowTransitionUtil = ( WorkflowTransitionUtil ) JiraUtils.loadComponent( WorkflowTransitionUtilImpl.class );
SubTaskManager subTaskManager = ComponentManager.getInstance().getSubTaskManager();
Collection subTasks = issue.getSubTaskObjects()
if (subTaskManager.subTasksEnabled && !subTasks.empty) {
subTasks.each {
log.debug ("issue.statusObject.name: " + issue.statusObject.name)
workflowTransitionUtil.setUsername(currentUser);
workflowTransitionUtil.setAction (101) // Transition ID e.g. 5 == RESOLVE ISSUE
// Add a comment so people have a clue why the child has been closed
CommentManager commentManager = (CommentManager) ComponentManager.getComponentInstanceOfType(CommentManager.class);
String comment = "*Assign Resolution* set as a result of the *Assign to Me* action being applied to the parent.";
commentManager.create(it, currentUser, comment, true);
// validate and transition issue
workflowTransitionUtil.validate();
workflowTransitionUtil.progress();
Any help would be appreciated.
Paul
Henning Tietgens
March 3, 2014
See my answer here.
pmooresaxton March 3, 2014
Thanks Henning. This works a treat.
Help us plant more trees
