Using R4J plugin, I'm unable to display the project field of a linked issueson a Word template
Laurent PIANFETTI November 2, 2023
Hello.
I'm trying to generate a specification document from my R4J Tree and I'm facing a issue when, for each issue of the tree, I try to display and use the project of a linked issue : null exception in the generated document.
Here is the extract of my template that generates the issue :
[[\if $.linkedissues.count > 0]]Linked requirements:
[[\variable.link_requirement ‘TRUE’]][[/variable]]
[[\each $.linkedissues]]
[[\if $.name = “contributes to”]]
Contributes to “[[$.issue.summary]]” ([[$.issue.key]]) [[$.issue.project]]
[[\\wiki $.issue.description]] [[/wiki]]
[[\variable.link_requirement ‘FALSE’]][[/variable]]
[[/if]]
[[/each]]
[[\if $variable.link_requirement = ‘TRUE’]]
None.
[[/if]]
Thank for your help
Angelica Salazar
November 3, 2023
Hi @Laurent PIANFETTI
      [[\wiki $.issue.description]] [[/wiki]]
      [[/if]]
  [[/each]]
None.
[[/if]]
[[/if]]
I tested this block of code that you have, and it does work. I just added a closing if block at the end.
If it's not working for you, there may be other parts of your template causing the null exception, so we'd need to have a look at your entire template.
If you require more assistance, our friendly support team will be happy to help!
Best regards,
Angelica
Laurent PIANFETTI November 6, 2023
Thank for your help @Angelica Salazar
Here is my code :
[[\template issueDetails]]
[[\variable.project $.project]][[/variable]]
URL de l’exigence : [[$.url]]
Description
[[\wiki $.description]][[/wiki]]
[[\if $.description = “”]]Pas de description[[/if]]
[[\if $.attachments.count > 0]]Pièces jointes :
[[\each $.attachments]]
[[/each]]
[[/if]]
[[\if $.linkedissues.count > 0]]Exigences liées :
Contribue à l’exigence “[[$.issue.summary]]” ([[$.issue.key]])
[[/if]]
[[/each]]
Aucune.
[[/if]]
Autres liens :
[[\if $.name = “relates to”]]
Est liée à l’exigence “[[$.issue.summary]]” ([[$.issue.key]])
[[/if]]
[[/each]]
Aucun.
[[/if]]
[[/if]]
[[/template]]
[[\each $selectedProject]]
[[\recurse $.folders]]
[[\levelheading $.name]]
[[\recursehere]][[/recursehere]]
[[\variable.parent $.key]][[/variable]]
[[\recurse $.folderissues]]
[[\levelheading “(“ + $.issuetype + “) “ + $.summary]]
[[\apply-template issueDetails]][[/apply-template]]
[[/levelheading]]
[[/recurse]]
[[/levelheading]]
[[/recurse]]
[[/each]]
Angelica Salazar
November 7, 2023 edited
I just copied your code into a Word document and tried to use it. It works fine for me. I am able to export without the null exception you mentioned.
Can you share the exact error you're experiencing?
Best regards,
Angelica
SERVER
Let's build A Rovo Agent 🤖
Save your spot
