Using Regular Expression Check as a validator in Workflow transition
Michelle Gronwold
Question, I have a single line text field called "Activity Rationale". I created a validator in a workflow transition to verify the text entered in this field is in a range of 1-200 characters long (below). But it is not working. Even if I enter just a couple of words in this field I will get the error message below. Is it because it is a text field that allows spaces? I'm stumped.
Regular Expression Check (JSU)
  • Field to be checked: Activity Rationale
  • Regular expression: ^[*]{1,200}$
  • Concatenate multiple values: false
  • Split on newline characters: false
  • Error message (optional): Activity Rationale field is limited to 200 characters
Vamsi Kandala
January 4, 2023 edited
Hi @Michelle Gronwold
Can you check and try this?
^.{1,200}$
Hope this helps.
Vamsi
Michelle Gronwold
Yes!! That worked! Thank you so much
Vamsi Kandala
January 4, 2023
Sounds good.
Vamsi
Like • Michelle Gronwold likes this
