Using Script, How can I manipulate date from customfield ?
Manuel Campomanes
I write a script using JSS plugin, I get back a date from a customfield and I need to extract data like day, month, year, hour and minute to use my own function and then to update the customfield.
But I have a problem to split the date in day, month, etc.
from com.atlassian.jira import ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import datetime
import time
import myLibrary
customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
customField = customFieldManager.getCustomFieldObject("customfield_10008") #dateEcheance
date = customField.getValue(issue)
day = datetime.datetime.strptime(date, '%d')
month = datetime.datetime.strptime(date, '%m')
year = datetime.datetime.strptime(date, '%Y')
hour = datetime.datetime.strptime(date, '%H')
min = datetime.datetime.strptime(date, '%M')
d = [int(day), int(month), int(year), int(hour), int(min)]
d2, mo2, a2, h2, mi2 = myLibrary.myFunction(d)
issue.setCustomFieldValue(customField, datetime.datetime(a2, mo2, j2, h2, mi2, 0))
Manuel Campomanes
I resolved my problem, the type return is 'java.sql.Timestamp' so I use this doc : [http://docs.oracle.com/javase/6/docs/api/java/util/Date.html]
from datetime import datetime
import java.sql.Timestamp
dateBlocage = customField.getValue(issue)
y = dateBlocage.getYear() + 1900
mo = dateBlocage.getMonth() + 1
d = dateBlocage.getDate()
h = dateBlocage.getHours()
mi = dateBlocage.getMinutes()
issue.setCustomFieldValue(customField, datetime(y, mo, d, h, mi, 0))
Manuel Campomanes
I think that the object return by "customField.getValue(issue)" is a java.sql.Timestamp, now I add to find how extract data from a java.sql.Timestamp!
