Using Script field in another script
Marzi Goodarzian
April 28, 2023
Hi
I wrote a script field previously, and now I want call this field in another script, but this field return null.
for example:
I wrote a field script that returm sum of a number fields in subtasks of a Issue(called Overall_Weight), and it returned correct answer and shown this answer in view screen.
Now ,I Called this field with by this method (issue.getCustomFieldValue(Overall_Weight) , but retuen null.
 I asked this question from Scriptrunner support , and tell me this problem fixed in jira 8.16  or above, my jira version is 8.5.0.
Did you use a solution in this version?
How to call script field in a another script?
2 accepted
Nic Brough -Adaptavist-
April 29, 2023
The short answer is that you don't.
Because of the way Jira works, you can not rely on the value of a scripted field being correct or even populated when you are running other scripts.
Your new script will need to replicate the code behind the scripted field.
Marzi Goodarzian
May 2, 2023
Fabio Racobaldo _Herzum_
Hi @Marzi Goodarzian ,
for my knowledge you can't reuse code in another context. The only way is to use the same code of your scripted field in your script.
Fabio
Marzi Goodarzian
May 2, 2023
Register today
