We want to have a listener on the "Issue Deleted" event that will write into a file the id of the deleted issue. I know th Auditor plugin logs this, but that info can't be accessed from a script so we need to make our own log.
I am playing around and trying this:
import org.apache.log4j.Logger
import org.apache.log4j.Level
File file = new File("test.txt")
file.write "Issue " + event.issue.getKey() + " was deleted"
log.debug("Issue " + event.issue.getKey() + " was deleted " + file.absolutePath)
It should be simple but the file is not at the location indicated by file.absolutePath. Why can't I find this file? Is there some restriction from Scriptrunner/Groovy for writing to my own files?
Our JIRA is running on Linux and it's inside a Docker container (I've already checked it and the file isn't there either)
Try the following piece of code. This will write to a file in JIRA_HOME directory.
import com.atlassian.jira.config.util.JiraHome
def jiraHome = ComponentAccessor.getComponent(JiraHome)
def file = new File(jiraHome.home, "test.txt") //location JIRA_HOME/test.txt
This will create and write to it.
Cristina,
You can try to save the file relative to JiraHome using
ComponentAccessor.getComponentOfType(JiraHome.class).getHome()
You can also use a concrete absolute path but this is less portable
If you use File("log.txt") it will be saved relative to the directory of execution.
Hope it helps
I tried using your solution but i get an error from the static code check saying that JiraHome is undeclared. How do I iniatialize it? I couldn't find anything in the API.
Additionally, if I try to specify the absolute path for the file like this:
import com.atlassian.jira.startup.JiraHomeLocator
def create = new File("/opt/ea/DIV_I/IC/IC_001/jira-home/scripts/com/listeners/test.txt").createNewFile()
def file = new File("/opt/ea/DIV_I/IC/IC_001/jira-home/scripts/com/listeners/test.txt")
I get this error:
2017-12-14 01:57:40,099 WARN [common.UserScriptEndpoint]: Script console script failed: java.io.IOException: No such file or directory at java_io_File$createNewFile$10.call(Unknown Source) at Script770.run(Script770.groovy:8)
If i skip the call to call to createNewFile() I get no error, but same as before no file is at the location that I indicate.
Any ideas?
Cristina
