Using a Scriptrunner Listener to keep FixVersions in sync
Melinda Atkinson
Our goal is to have a listener that will run and ensure that if the FixVersion of a Story is updated, that it will trickle down the update to the associated subtasks.
I have made this change for a custom field we are using called "Team" as follows.  When running, it will copy the Team field to its subtasks when updated.  For some reason I can't get the same script to work for FixVersion - can someone help me?
Here is my script in use for event: issue updated for our custom field = 'Team' (adapted from Adaptavist documentation):
def change = event?.getChangeLog()?.getRelated("ChildChangeItem")?.find {it.field == "Team"}
if (change) {
log.debug "Value changed from ${change.oldstring} to ${change.newstring}"
// your actions if the field has changed
def subtasks = event.issue.getSubTaskObjects()
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Team")
if (subtasks){
subtasks.each {it ->
def options = ComponentAccessor.getOptionsManager().getOptions(customField.getRelevantConfig(it))
((MutableIssue) it).setCustomFieldValue(customField, options.find {it.value == change.newstring})
ComponentAccessor.getIssueManager().updateIssue(event.user, ((MutableIssue) it), EventDispatchOption.DO_NOT_DISPATCH, false)
Thanks in advance.
Nir Haimov
December 9, 2018
Can you also show the code you tried for "fix version"?
Melinda Atkinson
It's the same as above but with FixVersion in the place of 'Team'.  but I realize this won't work as it is a core field and not a custom field - hence, why I'm asking what code should look like when referencing a core field.  Any help would be much appreciated, thank you.
Nir Haimov
December 10, 2018
FixVersions act and stored differently than drop down field, it's a collection.
You have a code solution here:
https://community.atlassian.com/t5/Marketplace-Apps-questions/JIRA-Script-Runner-Append-version-to-Fix-Version-s/qaq-p/593416
Like Dave Liao likes this
Nir Haimov
December 10, 2018
Let me know if you managed to make it work for you
Melinda Atkinson
Thanks Nir - not had a chance to try yet, but will keep you posted.  Thanks for your assistance so far.
