Using calculated number field
Sahil Arora May 5, 2017
I'm trying to use a calculated number field to calculate "weight/urgency" using two custom(severity and priority) fields.
<!-- @@Formula:
int r1 = 0;
int r2 = 0;
String severity= issue.get("customfield_10705");
String priority= issue.get("customfield_10704");
if("S1".equals(severity))
r1 = 4;
else if("S2".equals(severity))
r1 = 3
else if("S3".equals(severity))
r1 = 2;
else if("S4".equals(severity))
r1 = 1;
else
r1 = 0;
if("P1".equals(priority))
r2 = 4;
else if("P2".equals(priority))
r2 = 3
else if("P3".equals(priority))
r2 = 2;
else if("P4".equals(priority))
r2 = 1;
else
r2 = 0;
return (r1 * r2);
This is what I'm using and it doesn't seem to work.
David _old account_
May 7, 2017
== doesn't work for strings. You need to use the equals method instead:
if ("P1".equals(priority))
Sahil Arora May 7, 2017
Hey David, thanks for the answer.
It still doesn't seem to work.
Is there anything else I might be doing wrong?
Sahil Arora May 9, 2017
Hey David, I've implemented the fix and it's still not working. Also, the field doesn't show up on the view screen.
What do you think I'm doing wrong?
