Using group membership as a filter
Lionel Cassin
1. I have a Group Custom Field called Custodians.
2. I want to create a filter that displays records only if the current user is a member of a group that is listed in Custodians.
3. For example, let's say user lcassin is a member of group Meanies. And "Meanies" is in the Group Custom field Custodians in several records. I'd like to have a filter that shows lcassin all those records.
Is this doable?
LC
Jobin Kuruvilla [Adaptavist]
October 16, 2013
JQL Tricks plugin (commercial) has a groupsOfUser function. You can do something like this for current user.
Custodians in groupsOfUser()
You can also check it for groups of specific user.
Custodians in groupsOfUser("XYZ")
Lionel Cassin
Jobin -
JQLT did exactly what I needed. Thank you! Thank you!
Register today
