I'm trying to display icons for a custom field with JIRA 5.0. Unfortunately, the descrion given here doesn't for me.
I created a custom list field with 4 options and pasted this into the "Description" field of the "Edit Custom Field Details" dialogue:
<script type="text/javascript">
customField = document.getElementById("customfield_10600");
for(var i=0;i<customField.options.length;i++) {
customField.options[i].className="imagebacked";
customField.options[0].style.backgroundImage="url(/jira/images/icons/priority_blocker.gif)";
customField.options[1].style.backgroundImage="url(/jira/images/icons/priority_blocker.gif)";
customField.options[2].style.backgroundImage="url(/jira/images/icons/priority_blocker.gif)";
customField.options[3].style.backgroundImage="url(/jira/images/icons/priority_blocker.gif)";
</script>
The field ID is indeed "10600", I got this from the URL of this dialogue.
In the screen I see when "Edit"ing the issue, I see the custom list field with the 4 options and with FireFox, the text seems to be indented a bit, but there is no icon visible, neither in the edit issue screen nor when viewing the issue nor in the issues list after adding the custom field to the list of visible columns. I had a look at the pages' HTML source and didn't find any line of the JavaScript given above.
Can anybody point out what I am missing?
Hi Marcus,
I use Icons on one of my customfield and it works fine. Note that :
1) on the create and edit mode, I don't see Icons (only text "Succes"/"echec" ...) . Only on view mode.
2) icons are on my jira server, on the "images" JIRA directory
My 3 values on the specific custom field:
<img src='../images/icons/emoticons/check.gif' alt='Passed' /> Succès
<img src='../images/icons/emoticons/warning.gif' alt='Not Completed' /> Non terminé
<img src='../images/icons/emoticons/error.gif' alt='Failed' /> Echec
Stephane,
I have not seen icons on the view mode at all. Please post if you happen to get the solution.
vlada,
In which browser and which version of Jira? It hasn't worked for me in 5.0.4.
JIRA version 5.2.2
I don't think that version of browser could affect this. But anyway:
Opera 12, FF14, IE8, Chrome: 24.0.1312.57
Just make sure that:
- path to image is correct (check Marcus post)
- Icon is only visible in view mode (attachment included - field severity), in edit mode there is no icon visible just text ...
Nice, works for me to for "full" JIRA. Doesn't work in JIRA Service Desk. JSD shows the full value.
I don't think that its a clean solution. When you try to filter the same "custom field", it will also gives you the long HTML code.
Unfortunately this solution won't work anymore with JIRA 7, just see https://jira.atlassian.com/browse/JRA-38866 Please support me there in voting against this decision to drop any possibility to design rich options
Commenting on an old thread here, but if anyone else finds this, give this new free plugin from Atlassian a shot -
it seems to be available only for self-hosted servers
Does anyone know of any changes to get the images in Edit Mode in JIRA 6?
I ended up creating a web panel (right column) displaying the field value and setting the background of a text block to the color that reflects the value.
Why not just HTML and provide a hyperlink in the field option? I added little flag icons to language selections for an "Affected Languages" field for my users (so the option for "French" had a small France flag next to it, etc.).
Marcus,
Have you found a solution yet?
Rajani
The CustomWare Traffic Lights plugin (https://marketplace.atlassian.com/36434) lets you add colors to existing fields.
Thanks Matt for offering the "CustomWare Traffic Lights" plugin as a solution. I am hoping to find a java example of how to add icons to values in a custom field (like the Priority field), so I can include this in my utilities plugin. Can you offer a java example of adding icons in custom fields or point me to somewhere I can learn about this?
Is there a way to do this in Jira 5.x? I would like to create a "needs code review" field with a small icon to make an issue very noticible in the Greenhopper rapid board.
Thanks for your advice! Unfortunately, that didn't help.
I checked the field configuration and in the description field, I found the JS code I defined for my custom field. Tried to remove the JS code from the field description, only using the field's configuration description but that didn't change anything.
Checking the URL of the View Field Configuration > Edit dialogue, I noticed that the ID changed. Editing the custom field's description from the field configuration page directed me to
/secure/admin/EditFieldLayoutItem!default.jspa?atl_token=[...]|lin&id=10303&position=24
while the dialogue directs me to
/secure/admin/EditCustomField!default.jspa?atl_token=[...]|lin&id=10600
So I tried both IDs in my JS code, 10600 and 10303 but didn't see any icon.
Any other suggestions? To be specific, I wanted to replicate the combination of icons+text for a custom field, just as seen with the standard fields Priority, Type and Status.
