Using plugin from another plugin
Mikhail Ershov April 18, 2019
Hi all,
I'm trying to call some plugin's API from another plugin. It typically works but in this case I see the following exception during deploy:
Unable to create application context for [com.openwaygroup.jira.clientPlugin], unsatisfied dependencies: none
java.lang.NoClassDefFoundError: com/openwaygroup/jira/wlsync/data/MarshalledSlogService
at java.lang.Class.getDeclaredConstructors0(Native Method)
Caused by: java.lang.ClassNotFoundException: com.openwaygroup.jira.wlsync.data.MarshalledSlogService not found by com.openwaygroup.jira.clientPlugin [378]
at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1532)
Provider's pom.xml
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<Export-Package>com.openwaygroup.jira.wlsync.data</Export-Package>
<Import-Package>org.springframework.osgi.*;resolution:="optional",
org.eclipse.gemini.blueprint.*;resolution:="optional", *;version="0";resolution:=optional
</Import-Package>
<Spring-Context>*</Spring-Context>
</instructions>
And the following classes
package com.openwaygroup.jira.wlsync.data;
@ExportAsService
@Component
public class MarshalledSlogServiceImpl implements MarshalledSlogService {
@Named
public interface MarshalledSlogService {
 Client's pom.xml
        <dependency>
<groupId>com.openwaygroup.jira</groupId>
<artifactId>OW_wls</artifactId>
<version>1.0.8</version>
<scope>provided</scope>
</dependency>
and the code
@Named
public class RestHelper {
@Autowired
public RestHelper(final @ComponentImport MarshalledSlogService marshalledSlogService) {
Because this approach works fine in another cases I definitely  missed some nuance but don't see what.
Thanks in advance for any recommendations,
Mike
Stephen Sifers
April 30, 2019
Hello Mikhail,
Something to be aware of is this is a support community and not often browsed by developers. We want to ensure you get the responses and answers you need so we would suggest you check out the Developer Community. The Developer Community may have more available resources to answer or address your developer questions.
Stephen Sifers
Mikhail Ershov May 1, 2019
Thank you @Stephen Sifers , I'll post it there
