Sign up Log in
Using string functions with Project Automations from codebarrel
Russell Stanford
I am working with a field that contains the summary of multiple linked issue using the {{destinationissue.summary}}, which returns the summary of the linked issue.
I have linked issue types of "Assigned" and "Unassigned".
The assigned link type populates a sing line text field using the
It also adds to the field if more than one issue with assigned is used, by using this code.
{{destinationIssue.summary}} {{issue.fields.Computer Name}}
 The issue is when I link a computer with the link type "Unassigned" I need to remove the summary from the single line text. I was trying to use the string manipulation functions, but I do not know if you can use smartvalues as the parameter for the function. Like this
From their help pages:
{{issue.summary.remove("l")}} returns Heo Word!
 I was trying this hoping to grab the summary of the issue I just linked and remove it from the custom field of "Computer Name":
{{issue.fields.Computer Name.remove({{destinationIssue.summary}})}}
 I am guessing I cannot add smart values to the parameters passed to the function. Is that right?
andreas
December 13, 2017
Hi Russell,
Yes that's correct. You can't currently use smart-values as parameters like this.
We don't really support this use-case currently.
  Andreas
