Validate the comments using groovy script
Software Asset Management November 5, 2017
I need to auto transition an issue based on comments.
for ex:
1. if the comment value is approved it need to move the status to approved.
2. If the comment value is rejected it need to move the status to rejected.
i need a groovy script to allowed the listeners to move the status.
Tarun Sapra
November 6, 2017 edited
This should be straightforward to implement
You can use the built-in script listener "Fast track issue on transition"
In this you can configure the listener to trigger it for the "issue commented" event for a specific project.
Based on the condition (Approve or Reject) you will need to add 2 listeners which fire two different transitions (approve in case of approve and so on )
In the conditions section you can check the "body" (for text "approve or "reject") of the last comment using the code snippet
ComponentAccessor.getCommentManager().getComments(issue).last().body
