Validating all checkboxes checked using JMWE
Iana
Hi!
I have a checkbox field with 7 options. I would like to create a validator that only allows the transition to happen if all of the options are checked. Any ideas on how I can do this?
Thanks in advance.
4 votes
Suprija Sirikonda _Appfire_
August 19, 2021
Hi @Iana ,
Add a Scripted (Groovy) Validator (JMWE app) and add the below Groovy script:
!issue.getAvailableOptions("customfield_10300") || (!!issue.get("customfield_10300") && issue.get("customfield_10300").size() == issue.getAvailableOptions("customfield_10300").size())
Replace 10300 with the id of the checkbox field.
The validator uses getAvailableOptions method to get the available options for the specified field and it returns true only if all the options are selected in the checkbox field. Else, it returns false if the field is empty or if all options are not selected.
Hope this helps!
Suprija
Iana
Worked like a charm. Thanks a lot!
Like • Suprija Sirikonda _Appfire_ likes this
Iana
Hi @Suprija Sirikonda _Appfire_ ,
Would you happen to know how to do this same thing in Jira Cloud by any chance?
Iana
David Fischer
Hi @Iana
You can't do exactly the same thing on Jira Cloud, because you cannot access the list of available options from Jira Expressions. So you'll need to hardcode in the validator code the number of options:
!!issue.customfield_10200 && issue.customfield_10200.length == 7
where customfield_10200 is the field ID of your checkboxes custom field and 7 the number of options (checkboxes).
Like • 2 people like this
Iana
Thank you @David Fischer . I was afraid that'd be the case.
