Hello, experts!
I faced with the problem of validation "select list field" via behavior plugin.
If I filled number fields then update the validation doesn't work properly, if try to update it once again that validation is working.
Here is my Code:
def CoP = getFieldByName("Currency of payments to partners")
def NC = getFieldByName("NC mark-up to Billable costs (if applicable)")
def OPNB = getFieldByName("Other payments to partners (Non-Billable)")
def HPNB = getFieldByName("Hosting payments to partners (Non-Billable)")
def HWNB = getFieldByName("HW payments to partners (Non-Billable)")
def PSNB = getFieldByName("PS payments to partners (Non-Billable)")
def SMNB = getFieldByName("S&M payments to partners (Non-Billable)")
def LPNB = getFieldByName("License payments to partners (Non-Billable)")
def OPB = getFieldByName("Other payments to partners (Billable)")
def HPB = getFieldByName("Hosting payments to partners (Billable)")
def HWB = getFieldByName("HW payments to partners (Billable)")
def PSB = getFieldByName("PS payments to partners (Billable)")
def SMB = getFieldByName("S&M payments to partners (Billable)")
def LPB = getFieldByName("License payments to partners (Billable)")
def TPP = getFieldByName("3rd party products")
String NCVal = NC.getValue()
String OPNBVal = OPNB.getValue()
String HPNBVal = HPNB.getValue()
String HWNBVal = HWNB.getValue()
String PSNBVal = PSNB.getValue()
String SMNBVal = SMNB.getValue()
String LPNBVal = LPNB.getValue()
String OPBVal = OPB.getValue()
String HPBVal = HPB.getValue()
String HWBVal = HWB.getValue()
String PSBVal = PSB.getValue()
String SMBVal = SMB.getValue()
String LPBVal = LPB.getValue()
String TPPVal = TPP.getValue()
if ((NCVal != "" ||) (OPNBVal != "") || (HPNBVal != "") || (HWNBVal != "") || (PSNBVal != "") || (SMNBVal != "") || (LPNBVal != "") || (OPBVal != "") || (HPBVal != "") || (HWBVal != "") || (PSBVal != "") || (SMBVal != "") || (LPBVal != "") || (TPPVal != "")) {
CoP.setRequired(true)
}else{
CoP.setRequired(false)
}Perhaps the "None" value is the reason of this issue.
Hope you help!
Hi Sergey,
what kind of custom fields are these ?
At first I would recommend you to refactor code like this. Current version is too hard to find bugs.
import com.atlassian.jira.issue.CustomFieldManager
CoP.setRequired(true);
List<String> customFieldsNames = Arrays.asList(
, "Other payments to partners (Non-Billable)"
, "Hosting payments to partners (Non-Billable)"
, "HW payments to partners (Non-Billable)"
, "PS payments to partners (Non-Billable)"
, "S&M payments to partners (Non-Billable)"
, "License payments to partners (Non-Billable)"
, "Other payments to partners (Billable)"
, "Hosting payments to partners (Billable)"
, "HW payments to partners (Billable)"
, "PS payments to partners (Billable)"
, "S&M payments to partners (Billable)"
, "License payments to partners (Billable)"
, "3rd party products"
CustomField customField;
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
for(String fieldName: customFieldsNames){
customField = customFieldManager.getCustomFieldObjectByName(fieldName)
if( issue?.getCustomFieldValue(customField).equals("") ){
CoP.setRequired(false);
break;
This is for groovy script, I am not sure is it suitable for behavior.
@Vasiliy Zverev thank you for the answer!
Your script doesn't work with behavior feature.
Are there any errors?
@Vasiliy Zverev greetings!
Code did not work out with behavior feature.
Solved via workflow validator (simple script validator).
if ((cfValues["NC mark-up to Billable costs (if applicable)"] != null) || (cfValues["License payments to partners (Billable)"] != null) || (cfValues["Other payments to partners (Billable)"] != null) || (cfValues["License payments to partners (Non-Billable)"] != null) || (cfValues["S&M payments to partners (Non-Billable)"] != null) || (cfValues["PS payments to partners (Non-Billable)"] != null) || (cfValues["HW payments to partners (Non-Billable)"] != null) || (cfValues["Hosting payments to partners (Non-Billable)"] != null) || (cfValues["Other payments to partners (Non-Billable)"] != null) || (cfValues["S&M payments to partners (Billable)"] != null) || (cfValues["PS payments to partners (Billable)"] != null) || (cfValues["HW payments to partners (Billable)"] != null) || (cfValues["Hosting payments to partners (Billable)"] != null)) {
if (! cfValues["Currency of payments to partners"]) {
return false
true
A validator will work for workflow steps, but that will only apply to changes that take place during a workflow transaction. If you want to guide edits to the issue as well, you will need to use a behaviour.
If Vasiliy's code isn't working, I'd recommend you try extending the FieldBehaviours class using the BaseScript annotation. In fact, you'll need to do this if the Behaviour script is being read from a Script File, instead of as an inline script. Something like...
import com.onresolve.jira.groovy.user.FieldBehaviours
import groovy.transform.BaseScript
@BaseScript FieldBehaviours fieldBehaviours
List<String> customFieldsNames = ["NC mark-up to Billable costs (if applicable)",
"Other payments to partners (Non-Billable)",
"Hosting payments to partners (Non-Billable)",
"HW payments to partners (Non-Billable)",
"PS payments to partners (Non-Billable)",
"S&M payments to partners (Non-Billable)",
"License payments to partners (Non-Billable)",
"Other payments to partners (Billable)",
"Hosting payments to partners (Billable)",
"HW payments to partners (Billable)",
"PS payments to partners (Billable)",
"S&M payments to partners (Billable)",
"License payments to partners (Billable)",
"3rd party products"]
boolean anyFieldsEmpty = customFieldsNames.any{ fieldName ->
CustomField customField = customFieldManager.getCustomFieldObjectByName(fieldName)
def value = issue?.getCustomFieldValue(customField)
value == null || value == ""
log.warn("Were any of the field empty: $anyFieldsEmpty")
CoP.setRequired(!anyFieldsEmpty)You'll also notice I added a log.warn statement. log.debug might be more appropriate, but then you'd need to turn up the logging level to debug for ScriptRunner.
That at least should give you a start at figuring out what went wrong with the behaviour. Of course, if the workflow validator is enough for your purposes, and you don't need this rule to be enforced except on workflow steps, that's fine. It just may be a bit opaque to a user why things aren't working. Also, it may prove easier to debug if you simplify the script the same way Vasiliy did your original...
boolean anyRelevantFieldsPopulated = customFieldsNames.any{ fieldName ->
cfValues[fieldName] != null && cfValues[fieldName] != ""
return !(anyRelevantFieldsPopulated && !cfValues["Currency of payments to partners"])
