Validator & Jira Suite Utilities - display asterisk on field label
Lynn Gariepy
March 4, 2014
I have Jira Suite Utilities intalled. I added a validator on the complete transition to make Dev Release Notes a required field. It works fine, but there is no indication (no asterisk) next to the field labe to warn the user that the field is mandatory before they click OK.
How can I add the asterisk?
Lynn Gariepy
March 16, 2014
done
Lynn Gariepy
March 10, 2014
Thank you.
Nic Brough -Adaptavist-
March 4, 2014
Ah, that's actually quite a hard one. Validators happen during the transition, whereas the asterisk is added by Jira core code by the "field configuration" code.
You'll need to code in some javascript to add the highlight you need. On every screen you use in the transitions :-(
RambanamP
March 5, 2014
as @ Nic said you need to add asterisk using javascript, check the following post @jobinhas explained with example
http://www.j-tricks.com/1/post/2012/09/silly-javascript-hacks-or-is-it.html
