Validator check on Create transition that assignee should not be empty.
Mohit Dhir
November 18, 2019 edited
I wanted to make the assignee mandatory for one of the project-issuetype. I have thought on the below.
  • I can not change the global settings as this is only for 1 project-issuetype.
  • We can not make the assignee field mandatory in the field configuration. ( not allowed in Jira).
  • I have script runner and tried the simple scripted Validator but it does not seems to work
          if ( issue.assignee.name == null )
              return false
         Tried the below as well.
         if (issue.getAssignee() == null)
              return false
I got to understand that many thing come sinto the effect once the issue is created however validators are to check before the issue is created.
Could anyone suggest a method using which I can access the create form elements and validate it.
Antoine Berry
Hi @Mohit Dhir ,
Your method is correct, please try this script :
import com.opensymphony.workflow.InvalidInputException
if (!issue.getAssignee()){
invalidInputException = new InvalidInputException("Assignee cannot be empty.")
throw invalidInputException
Antoine
Mohit Dhir
Hi @Antoine Berry
Thanks for your help. Now I understand that it needs to be an exception to terminate.
it worked thanks.
Like • Antoine Berry likes this
Mohit Dhir
Tried the below as well. Same no effect
return false
