I create rule for clculate the difference betwen the Start Date and End Date usin these smart values:
- {{issue.start date.diff(issue.due date).days}}
the rule should edit a field validator if the difference btwen the dates its over 3 days after start date or before the start date to validate with the workflow.
The proble is that the rule its not editing the fild and i belive its because the smart value its not working propertly
Hi @Enmanuel V_
The smart value for D"ue Date" is: {{issue.duedate}}
Try that and if it still not working, Start Date is probably a custom field, try to use the field ID option.
Example {{issue.customfield_xxxxx}}
