While writing the JQL query getting the following error - The option 'xyz' for field 'abc' does not exist. Can anyone help me here?
Its only happening with the newly created values
Check your custom field context. Are the values different from project to project or even issue types? We are going to need more info that you currently provide in order to answer this question of yours.
Thank you for your response!
The context is dedicated to the project and the values are different from other projects and there are no dedicated Issue types for this context its global
Can you verify that this value exists on your field? A few screenshots would help.
@Swati_Mathapati try to edit the field's values and see if there is any space at the end of the value AND/OR if any letter is typed with a different character.
Does your filter works with other values of that field?
Yes ,it works with the other values not with the newly created values
@Swati_Mathapati what do you mean with the "newly created issues"? You pasted an image of a quick filter. What does quick filter have to do with new issues? You are not being detailed on what you want to achieve and what are the steps taken to achieve this. Perhaps someone else is willing to put more effort into getting a more details description of your problem. I'm sorry but I don't think I can help you any more, and maybe another fellow leader can.
Sorry about my last comment, I meant to say error is for newly added values/options in the field
Thanks for your efforts
