Velocity template not reloaded
Adam Hraban June 15, 2020
we work on a small Jira plugin, it should display number of logged hours in a small web-panel on issue page. In my local dev environment the data is automatically refreshed each time a new time is logged. As soon as we deploy our plugin to test environment - the data in velocity template is never refreshed.
I have tried to change settings of velocity.settings based on https://developer.atlassian.com/server/confluence/disable-velocity-caching/, but it did not help.
My questions:
1) Is there any other settings that should be changed to make velocity template auto-reload?
2) Should velocity.settings be the key to autoreload - how do I change its setting in target Jira instance (its not difficult to manually change it on my local environment, but how do I force these changes to test environment)?
Thank you
Explained - using Tempo Timesheet plugin to log work with "Log Time" was causing this issue. When we log work by using simply Jiras default "Log work", web-panel is reloaded correctly
Gonchik Tsymzhitov
How did you find it?
I am experiencing the same thing
Register today
