'View Workflow' Link on Issues is Broken
KeriB April 8, 2012
I have a weird problem. On two of our issue types, Prod Bug and QA Bug, the 'View Workflow' link next to the status on issues is broken. It gives this error message:
The requested content cannot be loaded. Please try again later.
Has anyone else had this problem? I just find it odd that it's only on those two specific issue types. I'm trying to figure out if I should just rebuild the workflows (custom ones, so it would be a pain) or what, as I can't find anything that would be causing this.
KeriB
Mirek
Hi KeriB,
I have faced this problem in the past..
Please look at your workflows names.. I am pretty sure that you use special characters in the name that are not allowed to render correcly in HTML, like for example "&" sign.
You do not need to rebuild your workflows. To fix this you should make a copy of existing workflows and workflow schemes that cause problems with a new names.. then assign new workflows to new workflow schemes.. and finally assign new workflow scheme to your project.
After that everything should work!
Mirek
Register now
