Viewing values entered on workflow screen transitions
AbrahamA
December 12, 2021
Hi
I have a mandatory field on workflow resolution transition. I made it mandatory using behavior.
Now when I view the screen, where do I see the value entered in transition screen.
If I add that custom field on the issue screen it is making the field mandatory on create screen itself.
Please let me know how to fix this issue.
Abe
3 votes
Fabian Lim
Hi @AbrahamA
You probably made the field mandatory in the field configurations which means it's always mandatory. What you need to do instead is to use the workflow validator explained here: https://support.atlassian.com/jira-cloud-administration/docs/configure-advanced-issue-workflows/
Regards
AbrahamA
December 12, 2021
Thank you. This solved my problem.
Read the story
