I, as Project Admin, cannot see - let alone edit - the Transitions properties (Conditions, Validators, Post functions...) in our workflow, which is shared with other projects. One has to be JIRA / System Admin to see / edit that.
I understand I cannot edit / update the workflow and its transitions as I want, since it is shared with others, but I cannot even _see_ what's configured.
Is there a way to come around that problem?
/Eric
Hi Eric,
As a project admin you can only see the workflow diagram not the conditions/validators/post functions.
Those topics are restricted to jira-admin, site-admin role.
Hope this helps.
HI @Eric C
No only users with admin permissions are able to instigate these kind of modification
