Want update test case result in JIRA using python
Ashish January 9, 2020
I want to update test case result in JIRA using python . If I give the JIRA ID it should update pass of fail.
Please help
Prem Singh August 30, 2020
did anyone got solution for this?
Cheney Ma [Go2Group]
January 9, 2020
Are you using any test management plugin like 'synapseRT' in your Jira instance?
If yes, you need check REST API introduced the plugin.
Thank you for your response .
We're using Zephyr .
January 9, 2020
You can raise a support ticket at: https://support.smartbear.com/message/?prod=zephyr
I believe someone from their team will assist you.
Read the story
