Is it possible to display the warning, note, info, tip, etc lozenge / call-out macros in JIRA comments? Often times we have large comments and even instructions for doing something within a JIRA issue and it would be nice to call out specific points using the call outs.
Even if this couldn't be done in comments, it might be nice to be able to do it in the description of an issue.
Although there is no such concept as call-out in JIRA, there are various options:
hope this helps,
Jacques.
You have to use the wiki markup renderer for comments for this to work. This could be configured in the field configuration.
Yea, the wiki-style renderer is enabled, its just I want to use certain macros. I already use the headings extensively which makes comments look much better, and I will try colors as needed. Thanks!
Hi
This is a bit late, but for anyone finding this now, we've developed the Quick Suggest Macros plugin.
It adds a few new macros into JIRA. Some of those are the Warning/Note/Info/Tip macros, along with a new autocomplete feature for all existing macros. Simply type a curly "{" brace, and the autocomplete dialog presents you with the available macros, and options to configure them.
Anthony
