We are not able to get data from scripted custom field(single issue picker) to summary
Mahesh Kallepalli
January 1, 2020 edited
Hello ,
We are Having scripted custom field with type single issue picker which contains drop down of other issues.
We need automatically move that field value to the summary. We worked around some code through listeners but it is taking the only "HR-125" but it is not reading the rest of the text. Could you please help us to achieve that at least we don't need that HR-125 our target is that only the text besides that key has to replaced.
Please find below code which you are using through listener
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager;
import com.atlassian.jira.issue.fields.CustomField;
import groovy.json.JsonSlurper
def eventIssue = event.issue
if(eventIssue.issueType.getName() == 'Onboarding-Manager Submitted'){
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField EmployeeName = customFieldManager.getCustomFieldObject("customfield_11602");
//Employee name customfield_11601 of Onboarding-HR Initiated
def summaryValue;
def cfv1 = eventIssue.getCustomFieldValue(EmployeeName);
log.warn('EmployeeName '+cfv1)
if(cfv1)
{ summaryValue = cfv1 }
def im = ComponentAccessor.getIssueManager();
log.warn('EmployeeName TETE '+summaryValue.toString())
def issueToChange = im.getIssueObject(eventIssue.id) as MutableIssue
issueToChange.setSummary(summaryValue.toString())
//def im = ComponentAccessor.getIssueManager();
//def issueToChange = im.getIssueObject(issue.id) as MutableIssue
Leonard Chew
January 3, 2020 edited
Hi Mahesh
If you have the key, you can get any data from that specific issue. In this example the summary of the key HR-125, which will probably be the name "John", if I understand your HR-Issue type correctly.
def cfv1 = "HR-125"
def issueManager = ComponentAccessor.getIssueManager()
def cfvIssue = issueManager.getIssueObject(cfv1)
log.warn('issue summary of HR-125 is: ' +cfvIssue.summary)
NCATS LAB
I'm unaware of any way to do this out of the box. You would need to parse the Employee name value and then update the Summary with this value.
There are a couple of add ons that could handle this easily.
https://marketplace.atlassian.com/apps/6820/scriptrunner-for-jira?hosting=server&tab=overview
https://marketplace.atlassian.com/apps/29496/jira-workflow-toolbox?hosting=server&tab=overview
atlassian, state of product 2026 webinar, product team report, webinar, product management, ai productivity, agile practices, team alignment, product report, atlassian learning, product strategy, discovery to delivery, survey insights
Webinar: State of Product 2026
We asked real teams how they’re coping with an industry in flux. Join this webinar to hear the research –plus tips for leveling up your team’s work.
Register now
