We are using the python scripts on dev instance jira 7.6.1.
somanath kondeti February 2, 2018
Currently, we are using the python scripts on jira 7.6.1 on dev instance. There is a one script used in project ISC central planing .In this project workflow, we have used this script.
Description: This script is used in ISCCP Jira project. (JIRAREQ-3648)
# This validate that "Fail Category" field is required when Component contains 'OARS' only for all types except bug type (JIRAREQ-3940).
# Date: 2016-03
# -*- coding: UTF-8 -*-
import com.atlassian.jira.issue.CustomFieldManager
result = True
description = 'Error - "Fail Category" field is required when Component contains "OARS"'
#get issue type
issueType = issue.getIssueTypeObject().getName()
if issueType != 'Bug':
#Check if component contains "OARS" value
components = issue.getComponentObjects()
if components is not None:
hasOarsComponent = False
for component in components:
if component.getName()=='OARS':
hasOarsComponent = True
break
if hasOarsComponent:
customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
cf = customFieldManager.getCustomFieldObjectByName("Fail Category")
if cf is not None:
cf_value = issue.getCustomFieldValue(cf)
if cf_value is None:
result = False
# this is an empty placeholder for edit validation script
With in the project, I am trying to create the issue, when i choose component=OARS except issue type "BUG"  Error - "Fail Category" field is required when Component contains "OARS"'
Can anyone tell me the , how can i overcome this issue.
somu
