  • Community
  • Q&A
  • Jira
  • Questions
  • We have a situation where in we have to asssign an issuore to reporter as well as Defect Manager. How can we do this using Validator
Jayashree Shetty
August 21, 2013
We have a workflow in which if we have any bugs/defects created then this needs to be assigned to both reporter and the defect manager. There is validator for assigning to reporter and also assign to role member. if we add both these validators how will they work ? will the issue assigned to both or is it one among the two assignees.
RambanamP
August 21, 2013
Nic Brough -Adaptavist-
August 21, 2013
First of all, a validator is absolutely the wrong place to do this. A validator is for checking input is correct, not setting data. You should be doing this in a post-function or a listener.
Secondly, you can't. Jira's assignee field holds a single value. Reporter OR defect manager. Whichever "set assignee" call you are doing second will overwrite the first.
I suspect that you might want to have a defect manager assigned constantly though - "this is the person responsible for handling it overall", with the assignee used for "this is the person currently dealing with the details".
I'd recommend having the defect manager as a second "user picker" field - that way it can remain static through the life of the issue, and the assignee can be changed to reporter, developer and so-on, as required.
A slightly improved version of this would be to directly use the defect manager in the workflow sometimes (e.g. "escalate to defect manager" - uses a plugin to update the current assignee to the defect manager, and the condition "only the defect manager can close the issue")
Jayashree Shetty
August 21, 2013
Thanks Nic. It was by mistake that i wrote validator instead of post function
