We want to set up Jira Server (Core, Software and Service Desk) + Confluence + Zephyr/ Xray/ TM4J + Bitbucket + Crowd infrastructure for our organization.
Team Structure:
Overall Stakeholders: 175-210
Developers: 80-90 , Testers: 25-30, BAs: 12-15, Support Team: 8-10, Others: 50-60
After seeing various guidelines posted by Atlassian (mentioned below for reference), we came up with below architectural design topologies.
https://confluence.atlassian.com/jirakb/jira-server-sizing-guide-975033809.html https://confluence.atlassian.com/adminjiraserver075/jira-applications-installation-requirements-935390824.html https://confluence.atlassian.com/enterprise/jira-sizing-guide-461504623.html https://confluence.atlassian.com/doc/server-hardware-requirements-guide-30736403.html https://confluence.atlassian.com/doc/example-size-and-hardware-specifications-from-customer-survey-76840961.html
We are planning to install and configure all above mentioned applications as per the below distributed topologies and hardware specs with almost (210 users, 120-140 Concurrent users, 350-500 Issues/month, 120-150 custom fields, 12-15 workflows, etc.)
Architectural Design Topology 1:
Application Server 1: (VM)
Server Specs: (RHEL 7)
vCPU: 4, RAM: 16 GB, Hard Disk Space: 200-250 GB
Application Server 2: (VM)
vCPU: 4, RAM: 16 GB, Hard Disk Space: 150-200 GB
Database Server: (VM)
vCPU: 4, RAM: 16 GB, Hard Disk Space: 250-300 GB
Architectural Design Topology 2:
vCPU: 4, RAM: 16 GB, Hard Disk Space: 100-150 GB
Application Server 3: (VM)
We need expert advice regarding above mentioned distributed topologies and hardware specifications from performance point of view with almost (210 users, 120-140 Concurrent users, 350-500 Issues/month, 120-150 custom fields, 12-15 workflows, etc.). Is it Ok OR need some modification?
We have also checked the pros and cons of installing multiple application on single server.
What could be the pros and cons of above architectural designs? OR Should we segregate/merge/change the apps server installation combination.
Tariq Ashraf
Hi!
Are you sure you need to have architect, as I see the requirements are too simple
