Webhook not triggered on status transition
kororos November 17, 2017
I have a workflow in Jira Cloud with the following statuses:
Open --> In Progress --> Done --> Open
I want a webhook to be triggered when the issues transition from In Progress to Done (In Progress --> Done). I did the following:
  1. Created a Webhook for the "updated" issue event
  2. Added the following JQL: STATUS CHANGED FROM "In Progress" TO "Done"
  3. Saved the webhook
When testing the webhook, I get the following result:
  • When the issue transitions from "In Progress" to "Done" the webhook is not triggered
  • But, when transitioning from "Done" to "Open" it is triggered. In fact it is also triggered for any transition thereafter.
I understand why it is triggered for every transition thereafter, however I do not understand why it is NOT triggered when transition to "Done" in the first place.
It appears as if the JQL is executed before the status has changed in the database and therefore it does not take into account the new status but the previous status.
If the above is the case, then this is not documented behavior. Can you please help me?
Darin Hafer
I'm having same issue as Lefteris. My webhook is triggered on all updates of the issue, except for when it transitions to Done.
Since I can trigger the webhook in a workflow, I set the trigger in the transition to Done...and it never gets triggered. (Jira server 7.9.2).
Tried to make a workaround but this appears to be a bug.
Faruk Cankaya
May 22, 2019
Is there any progress in this issue? I've a similar problem, too. Let me clear it, I've 8 step in my workflow:
- Ready for Dev
- Test Fail
- In Dev
- Code Review
- Ready for Test
- In Test
- Ready For Deployment
- Done
I added webhook to "Test Completed" transition between "In Progress Test" and "Ready for Deployment" steps. Here are the post functions of the transition:
The following will be processed after the transition occurs
  1. Set issue status to the linked status of the destination workflow step.
  2. Send transition to webhook: WEBHOOK TEST
  3. Add a comment to an issue if one is entered during a transition.
  4. Update change history for an issue and store the issue in the database.
  5. Re-index an issue to keep indexes in sync with the database.
  6. Fire a Generic Event event that can be processed by the listeners.
Expected behavior:
Trigger WEBHOOK TEST  function when an issue moves from In Test step to Ready For Deployment step. But webhook is not triggered. I checked activity of issue on this step and it seems that status is changed properly which says:
Faruk Cankaya changed the status to Ready for Deployment on X-1000 - Issue Name
However, webhook is triggered if an issue moves from "Ready for Deployment" to any another step which is unexpected behavior.
I think it's caused by the order of post functions. I fired the webhook transition at last after the 6. step named "Fire a Generic Event event that can be processed by the listeners." but the behavior was not changed.
Finally, my webhook configuration is like that:
Issue related events
JQL: project = PROJECTNAME AND status = "Ready for Deployment"
Issue: created, updated, deleted, worklog changed
Michael Lasonde
Any kind of solution for this? i only want to get a webhook notification sent when Arch = Security and Status changes from Investigating to Escalated. Any help would be appreciated.
Faruk Cankaya
May 12, 2020
Nope
Sonal Singh June 11, 2020
hey, I am new to JIRA and facing a similar issue. I need to trigger a database function based on the status change. say when the status changes to 'Ready for deployment' then JIRA should trigger a DB function.  I was thinking of using webhooks, any idea how this can be achieved.? TIA
Taras Shved
October 2, 2020
Alexey Matveev
November 17, 2017 edited
First of all jql query is executed upon the lucene index, not database. And are you sure that transition from In Progress to Done fires issue updated event? Have a look at the fired event on this transition.
kororos November 18, 2017
I had a look at the jira event. Part of the JSON received is
"webhookEvent":"jira:issue_updated"
Like • Vincent van ’t Zand likes this
Alexey Matveev
November 18, 2017
  But you said the web hook did not fire. How come there is a part of JSON received?
Hello Alexey and thanks for your time.
In fact, I said it did not fire on transitioning from "In Progress" --> "Done". Thereafter, the event triggers. So after the first transition from "In Progress" --> "Done" it gets triggered. Just so that I am more specific:
  1. Create new issue (status "To Do")
  2. "Open" --> "In Progress" : Event is not triggered (expected behavior)
  3. "In Progress" --> "Done" : Event is not triggered (UNEXPECTED behavior)
  4. "Done" --> "Open" : Event triggers (expected behavior - the issue has transitioned at least once from "In Progress" to "Done")
  5. "Open" --> "In Progress" : Event gets triggered (expected)
  6. "In Progress" --> "Done" : Event gets triggered (expected)
  7. etc.
Hope it is a bit more clear now.
Thank you
Alexey Matveev
November 18, 2017
What I meant go to the transition which goes from In progress to Done. Open post functions tab and have a look what event is fired there. If it is not issue updated event then either change it to the issue updated event or add this event to the webhook triggers.
Alexey Matveev
November 18, 2017
I think maybe it can be the issue resolved event which fires on this transition that is why the webhook does not fire because it is not the issue updated event.
Alexey Matveev
November 18, 2017
ah, sorry. Number 6 is from in Progress to Done and it fires. I guess the event is correct.
I checked the post functions, and I saw the following:
  2. Add a comment to an issue if one is entered during a transition.
  3. Update change history for an issue and store the issue in the database.
  4. Re-index an issue to keep indexes in sync with the database.
  5. Fire a Issue Closed event that can be processed by the listeners.
I think that the problem may be coming from the fact that at step 3 the change history is updated (and possibly Issue Updated event is fired) and then in step 4 the issue is re-indexed. As a result, my JQL running at step 3 may not see the issue as in status changes from "in progress" to "done". I will updated the post functions and try it again. I will post the update.
Alexey Matveev
November 18, 2017
I guess that is the case:) Better add issue closed to the webhook trigger.
Unfortunately, I cannot change the order of the default Post Actions. I guess I am currently stuck with this for now. As a workaround, I can get the webhook to be called for every issue_update event and then check in my external application what the reason for the update was. Of course this is very bad practice since I will be getting a lot of traffic when only a small fraction of that is useful.
How would I add Issue Closed to the webhook trigger? This is a fixed list where there is no "issue closed" event. See screenshot:
Alexey Matveev
November 18, 2017
Yes, you are right. Not all events are available. I guess the only choice to add the update event. Or to fire it in the transaction as a post function.
Alexey Matveev
November 18, 2017
you can explicitly fire it from the transaction. Just add Trigger a webhook post function.
kororos November 19, 2017
I could do this, the only reason that I have not done so is because I am aware that there is a bug open about triggers in post functions that do not fire reliably webhooks (see here).
JDave
Did you ever get anything to work?   The webhooks have not been updated or fixed .. I'm in the same situation .. with trying to launch a webhook when our incidents transition to Done
Like • Carol Li likes this
Help us plant more trees
