I try to call remote webservice form my JIRA plugin (jira version 6.2). I failed with jax-ws client, couldn't resolve dependency problems.
Which tool should I use: Axis2, CXF or something else? Do you have any positive experiences?
It works with Axis2, with these dependecies:
<!-- AXIS --> <dependency> <groupId>org.apache.axis2</groupId> <artifactId>org.apache.axis2.osgi</artifactId> <version>1.6.2</version> </dependency> <dependency> <groupId>javax.servlet</groupId> <artifactId>servlet-api</artifactId> <version>2.4</version> <scope>provided</scope> </dependency> <dependency> <groupId>xml-apis</groupId> <artifactId>xml-apis</artifactId> <version>1.0.b2</version> <scope>provided</scope> </dependency> [...] <jira.version>6.2</jira.version>
I also had to configure osgi dependencies manualy in my atlassian-plugin.xml because import of org.w3c.dom was not generated autamitacally.
How did you configure the org.w3c.dom dependencies in the atlassian-plugin.xml file? Can you show an example.
