I'm trying to fix the following stacktrace, apparering in logs during Jira startup. It doesn't prevent Jira from running (ie I can access the UI after a while), but I'd really like to avoid this:
2012-07-03 14:35:26,256 Thread-2 INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.jirafisheyeplugin, com.atlassian.jira.jira-issue-link-applinks-common-plugin, com.atlassian.jira.gadgets, com.atlassian.soy.soy-template-plugin, com.atlassian.jira.rest, com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.crowd.embedded.admin, com.atlassian.plugins.rest.atlassian-rest-module, com.atlassian.oauth.serviceprovider, com.atlassian.streams.streams-jira-plugin, com.atlassian.jira.jira-issue-link-confluence-plugin, com.atlassian.gadgets.dashboard, com.atlassian.gadgets.embedded, com.atlassian.oauth.admin, com.atlassian.gadgets.oauth.serviceprovider, com.atlassian.jira.jira-view-issue-plugin, com.atlassian.streams.core, com.atlassian.jira.jira-project-config-plugin, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.streams, com.atlassian.gadgets.directory, com.atlassian.applinks.applinks-plugin, com.atlassian.jira.plugins.jira-importers-plugin, com.atlassian.activeobjects.activeobjects-plugin, com.atlassian.jira.jira-issue-link-remote-jira-plugin, com.atlassian.gadgets.opensocial, com.atlassian.jira.jira-invite-user-plugin, com.atlassian.jira.plugin.ext.bamboo, com.atlassian.streams.actions], 58 seconds remaining 2012-07-03 14:35:25,709 Spring executor 10 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.crowd.embedded.admin org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'handler' defined in URL [bundle://26.0:0/META-INF/spring/web-context.xml]: Initialization of bean failed; nested exception is java.lang.NoClassDefFoundError: javax/servlet/ServletContext at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409) at java.security.AccessController.doPrivileged(Native Method) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:728) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355) at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320) at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132) at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) at java.lang.Thread.run(Thread.java:662) Caused by: java.lang.NoClassDefFoundError: javax/servlet/ServletContext at java.lang.Class.getDeclaredMethods0(Native Method) at java.lang.Class.privateGetDeclaredMethods(Class.java:2427) at java.lang.Class.privateGetPublicMethods(Class.java:2547) at java.lang.Class.getMethods(Class.java:1410) at java.beans.Introspector.getPublicDeclaredMethods(Introspector.java:1284) at java.beans.Introspector.getTargetMethodInfo(Introspector.java:1158) at java.beans.Introspector.getBeanInfo(Introspector.java:408) at java.beans.Introspector.getBeanInfo(Introspector.java:167) at java.beans.Introspector.getBeanInfo(Introspector.java:230) at java.beans.Introspector.<init>(Introspector.java:389) at java.beans.Introspector.getBeanInfo(Introspector.java:167) at java.beans.Introspector.getBeanInfo(Introspector.java:230) at java.beans.Introspector.<init>(Introspector.java:389) at java.beans.Introspector.getBeanInfo(Introspector.java:167) at java.beans.Introspector.getBeanInfo(Introspector.java:230) at java.beans.Introspector.<init>(Introspector.java:389) at java.beans.Introspector.getBeanInfo(Introspector.java:167) at org.springframework.beans.CachedIntrospectionResults.<init>(CachedIntrospectionResults.java:220) at org.springframework.beans.CachedIntrospectionResults.forClass(CachedIntrospectionResults.java:144) at org.springframework.beans.BeanWrapperImpl.getCachedIntrospectionResults(BeanWrapperImpl.java:252) at org.springframework.beans.BeanWrapperImpl.getPropertyDescriptorInternal(BeanWrapperImpl.java:282) at org.springframework.beans.BeanWrapperImpl.isWritableProperty(BeanWrapperImpl.java:333) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1247) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472) ... 18 more Caused by: java.lang.ClassNotFoundException: javax.servlet.ServletContext at org.apache.felix.framework.ModuleImpl.findClassOrResourceByDelegation(ModuleImpl.java:772) at org.apache.felix.framework.ModuleImpl.access$200(ModuleImpl.java:73) at org.apache.felix.framework.ModuleImpl$ModuleClassLoader.loadClass(ModuleImpl.java:1690) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) ... 43 more
which repeats several times
I searched in my filesystem, I only have 1 servlet-api.jar which is located in my tomcat's lib dir...
Additionnaly, I have lots (about 40) lines like this, speaking about threads and threadlocals, during shutdown:
SEVERE: The web application [/jira] appears to have started a thread named [QuartzWorker-0] but has failed to stop it. This is very likely to create a memory leak. Jul 3, 2012 2:37:41 PM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [/jira] appears to have started a thread named [JonasBatch] but has failed to stop it. This is very likely to create a memory leak. Jul 3, 2012 2:37:41 PM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads SEVERE: The web application [/jira] appears to have started a thread named [JonasClock] but has failed to stop it. This is very likely to create a memory leak. Jul 3, 2012 2:37:41 PM org.apache.catalina.loader.WebappClassLoader clearReferencesThreads
Any clue?
Thank you!
Have you marked a Provided scope dependency in your plugin for javax.servlet-api ? Because you are in a plugin you may not have access to the class. I use servlet api often, not in tomcat7, though, my pom contains:
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>servlet-api</artifactId>
<version>2.5</version>
<scope>provided</scope>
</dependency>
Oh, also, Tomcat 7 isnt a supported platform either, perhaps that mean untested, perhaps that it just wont work...
https://confluence.atlassian.com/display/JIRA/Supported+Platforms
Hum I don't use Maven for this, and I don't build anything myself (I use the Jira shipped, out of the box, no additionnal plugin).
But as you said in your message, Tomcat 7 is not supported, so I'll stop trying to make it work and downgrade to a 6.x.
Thank you for pointing me on the right direction!
I confirm: no more exception when using Tomcat 6
I guess that's the price to pay for using Atlassian's product in an unsupported container. Seeing the same behavior for other not supported containers as well, like winstone, glassfish, jetty, tjws etc.
Check your generated JAR, you'll probably have a servlet jar in there, fix your dependencies such that servlet-api is provided scope.
Sorry but there is no other *servlet*.jar anywhere, I've opened every jar located in web-inf/lib to find anything related to javax.servlet, but there isn't any.
For information, I'm using Jira 5.0.4, Tomcat 7 and Mysql. I've built it using the provided batch, then removed the slf4j/log4j libs and put them into my tomcat's lib directory... I don't have any other plugin installed yet.
more infos:
I'm able to reproduce the exact stacktrace on my local machine (Win xp) with Tomcat 7, but not with Tomcat 6!
could anybody confirm that?
Learn more
