What are the JIRA scaling issues when we push thousands of test executions (via ZAPI) to JIRA?
njavagal
March 9, 2015
We plan to push around 20000 (20K) test executions to JIRA via ZAPI. Will the lucene index behind JIRA scale? What are some of the best practices here?
Daniel
April 2, 2015
Just to chime in. From testing, you would be looking at about ~7 minutes per thousand executions. During this time, you would expect the CPU load to reach very high thresholds but the memory requirements will only reach roughly 3GB during the process. These numbers include other services and JIRA itself on the machine.
njavagal
March 10, 2015
I would like to discuss this feature with you. What would be a good time to talk?
MattS
March 10, 2015
I've discussed the idea of uploading a JSON file containing multiple execution results to improve the overall duration. What do you think to the idea of adding such a feature to ZAPI?
MattS
March 10, 2015
Each of the 20K operations would update a custom field (build version) and set the result of a test (Pass/Fail/etc). How long would the whole 20K typically take, and what would the impact be on other JIRA users?
Read the story
