×On my Jira instance, someone changed all the Issue Linking types and I can't find the defaults documented anywhere. Can someone post a screenshot or list of the original Jira Issue Link types?
They are located at [your jira]/secure/admin/ViewLinkTypes.jspa
Hi Brian,
These are the 4 default issue links in Jira:
See Configuring issue linking for more information.
Absolutely, here they are in the same order as the outward/inward list above:
@Mikael Sandberg the default for my link type is "causes" I want the default to be "blocks" when creating a linked issue. Is there any possible way to do this?
@jhuynh The link types will be displayed in the order they are defined, but there two tickets logged to be able to change that order, see JRACLOUD-16281 and JRASERVER-16281. If you want to see this feature implemented go ahead and add your vote to the suggestions.
