Sign up Log in
What do I need to do to get Jira Toolkit messaging working properly...?
Adam Grace
Hi all,
I'm very green when it comes to JIRA plugins. I've learnt a lot through trial and error, however I've arrived at a point where nothing I do with JIRA Toolkit works.
I want to create a Message Custom Field at key points in my workflow to instruct the user on what they need to do.
I don't know the difference between the Message Custom Field (view) and Message Custom Field (edit).
So far I've;
  • Installed the plugin via the plugin manager.
  • Rebooted JIRA
  • Added two Message Custom Field (view and edit)
  • Applied them to a screen (QA Pass)
  • Re-indexed JIRA
  • Applied the workflow to the project
  • Arrived at the transition where the message should appear, and see nothing.
Am I missing a vital step here, of have I found a bug. I've uninstalled and reinstalled the plugin, triple checked all my steps. Searched online for the last 24 hours.. i Cannot see the cause...
I really need help here :(
Joe Pitt
March 13, 2012
The view and edit message fields appear on the view and edit screens as defined in the issue screen scheme. They don't appear on transition screens.
Jobin Kuruvilla [Adaptavist]
March 13, 2012
Ah right. Here is the ticket: https://studio.plugins.atlassian.com/browse/JTOOL-63
Adam Grace
When you say they won't appear on the transition screen do you mean the third screen I attached above? If so, how is this different to the way Atlassian use it in their create issue screen (see below)
Dave Donnelly _Sensata_
March 13, 2012
Adam Grace
I've already seen (and replied) to that thread. I've tried what he suggested, and nothing seemed to work.
March 13, 2012
See that now. Sorry - missed that Adam. My thread was on JIRA 4.3.4 must be something different in v5. Hope you get sorted.
Adam Grace
No worries David. I'm sure I'm doing something wrong.. others that have asked about this seem to have solved it. I wish there was a youtube video or some kind of tutorial.. I feel more and more stupid
Joe Pitt
March 13, 2012
I believe the create screen counts as an Edit screen.
Adam Grace
I see, so techincally.. what I want to achieve (instructions during transitions) is not currenctly doable? That link above (to the Jira bug/feature request) is closed now.. :(
March 13, 2012
Under configuration of the field, have you edited the default value and added your message?
Adam Grace
I haven't put anything in there.. I didn't even know there was such an option. The default value is blank. what do I enter here?
March 13, 2012
You click on Configure Custom field and Edit the default value. But as Joe said, you will get it working only on Edit and View screens it seems.
See http://confluence.atlassian.com/display/JIRA/Configuring+a+Custom+Field#ConfiguringaCustomField-DefaultValue
Jörg Lang April 24, 2012
I have the same issue.
Any update on this?
I have defiend "default value" and nothing is shown :(
Im using 5.0.2
Adam Grace
Sorry Jörg, I never solved this.
Jörg Lang April 26, 2012
that's bad :( thanks for letting me know
