What does "updated" JQL actually cover?
Ina Ivaylova August 10, 2017 edited
I am wondering what does the "updated" actually means in JQL: Does it cover absolutely any change to the issue or is just some particular modification?
For example, if a user logs time under the issue, does that mean that issue was "updated"?
2 accepted
5 votes
Tarun Sapra
Hello Ina,
"Updated"  does cover any change to the issue. And Yes logging work/time on an issue is covered by the "updated"
Ina Ivaylova August 11, 2017
Hi @Tarun Sapra
This is great, thank you.
Is there a way to specifically look for updates in the worklog/time?
For Example:
worklogDate >= "2017/08/01" && worklogDate <= "2017/08/11"
- Is this going to filter all updates on the worklog between those days?
CC- @Umer Saeed
Tarun Sapra
August 11, 2017 edited
"Is this going to filter all updates on the worklog between those days?"
No, that's not the case. Because workLogDate basically means the "Date selected" while logging work - https://jira.atlassian.com/browse/JRASERVER-1959
This date can be in future as well. So the JQL which you have shared will only fetch issues which have the workLogDate in the specificed time-period.
For example - You can log your work on an issue today and while logging work select the workLogDate as 20 August. So when you search using "updated" field like
updated > startOfDay()
Then you will get the issue which you updated with work log but if you try
worklogDate <  endOfDay()
 Then you won't get this issue because you updated the issue today but the worklog date you selected is for 20-August
Okay, got it.
So WorkLogDate is not connected to the act of updating but to the content you write there.
Good to know, @Tarun Sapra
So when it comes to updates, the only thing I can actually query using JQL is the overall update on the issue (using the "updated").
Do you thing there is any way to specify that we are looking into updates of a specific information, which in this case is whether the worklogs were updated?
Cheers
Umer Saeed
'updated' specifically works for the following actions:
And you can use the preset functions for the timing periods, such as:
updated < startOfDay()
It doesnt really work for =, !=, is, is not, in, not in
And yes, it will be to find any action on the ticket that was updated within the given function timing period
René Warsow June 16, 2025
Problem with updated field
I want to see which issues were worked on last week - simply: any change that appears in the issue history.
But the updated field does not reflect the last change in history. It also changes when internal updates happen (e.g. database updates, SLA recalculations, system processes).
So updated is basically useless for tracking "activity".
I need a way to filter based on any history entry, not just this unreliable updated timestamp.
Georgia Harty
June 5, 2024
Does 'updated' include when an issue is linked to another? I have the same issues showing in a JQL for both actioned and not actioned in the same time period.
Harry Bob
May 31, 2020 edited
Can you confirm if you're able to use 'updated' like below?
updated >= 5m
I tried it but doesnt seem to work. Cant seem to find any documentation regarding it.
Hinnerk Mahnken
September 22, 2020
Use -5m since its relative to "now" i guess
Tommy Craft January 14, 2025 edited
Does this actually work for anyone?
If I use
Status = "Waiting for Customer" AND Updated > -10m AND Organizations = "zzTest - Testing Org"
in the Scheduled Automation JQL, it comes back as valid; however running it in the Issue Search returns no results.
If I use
Status = "Waiting for Customer" AND Updated < -10m AND Organizations = "zzTest - Testing Org"
then I get accurate results in the Issues Search but it fails validation in the Scheduled Automation JQL
Learn more
