I wanted to pull out the data for BUG Severity, where i saw the Irrelevant Data. What does that mean ?
Hi there,
Irrelevant means that the parameters of your filters are met, but the grouping field you are choosing may not be related to certain issues.
For example,
Using Two Dimensional filters gadget; filter = All issues and where XAxis is a custom field and, YAxis is Issue Type
Filter results in several issue types but, if any of those issues have not any value on the custom field, they will be shown as Irrelevant on your gadget.
Hope this helps to understand!
It looks like Irrelevant shows up when Chart is unable to determine the value for the field you are grouping by.
Hope this helps!
