I was wondering what happens when I change the name of an existing / used resolution name. e.g. rename "Won't do" in "rejected". Are there any side effects? e.g. filters that are not working anymore?
Thanks in advance
Bernd
Filters looking for it will indeed stop behaving, but that's about it. The name of a resolution is very much a label on an underlying object.
Thanks.
Is there any easy way to determine which, if any, filters use a given resolution name (on Jira cloud)?
I.e Given that, if I change a resolution name, filters may stop working. How do I determine what the damage will be when I change a resolution name?
