What is the best way to determine if Jira servers should be merged or federated?
Rob Horan
December 29, 2017 edited
I administer a Jira server for my team and a few others.  Due to an acquisition we now have a larger, organization-wide instance of Jira as well.  We need information from my smaller instance available to the larger.  (Searches, dashboards, links, etc) I am not sure of how best to go about this, or what the potential dangers there are.  Any help would be very much appreciated. One server uses crowd for user accounts, the other does not.  All users in my instance have active accounts in the other.
Anyone with experience with the Project Configurator add on, please let me know!
https://marketplace.atlassian.com/plugins/com.awnaba.projectconfigurator.projectconfigurator/server/overview
Edwin Kyalangalilwa
Hi Robert,
To be merged, the JIRA's will have to be on the same versions. Then you can take an export from either your instance or the other and use the Project Import functionality.
https://confluence.atlassian.com/adminjiraserver/restoring-a-project-from-backup-938847691.html
The dashboards and links will need to be recreated.
Rob Horan
December 29, 2017
That seems.... way too easy.  Theres got to be a ton of other factors to consider.  Fields, workflows, etc?  Am I overthinking?
Rob Horan
December 29, 2017
Seriously, I can't even upgrade my test server using their installer without $#(@# blowing up on start.
Edwin Kyalangalilwa
January 4, 2018
Yes, fields will need to be recreated. But importing the workflows will create these fields as well in the process.
Following the supported platforms for your versions shoud help with the upgrade process. What kinds of errors do you get?
Rob Horan
January 8, 2018
Hi Edwin, I just realized, these instructions are for a single project.  I need to move EVERYTHING.  Not just one project.
Edwin Kyalangalilwa
January 10, 2018
This is the option of merging the two. The other type is restoring the whole system which would delete all data in the target instance.
Rob Horan
January 20, 2018
Ummm... destroying the other instance is not an option.  I'm not quite sure how that would help :)
atlassian, state of product 2026, product teams report, developer experience, product manager survey, AI impact, product team stress, product teamwork, dev workflow insights, 1000+ PMs, product leadership research
State of Product 2026
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
