What is the smartvalue for "original estimate" or any time estimate in lookupissues in Jira data center?
For {{issue}} the following works
issue.timetracking.originalEstimate
issue.timetracking.originalEstimateSeconds
For {{lookupIssues}} I have tried the following syntax but none of them work and it is pretty poorly documented.
lookupIssues.Original Estimate
lookupIssues.originalestimate
lookupIssues.originalestimation
lookupIssues.timetracking.originalEstimate
lookupIssues.timetracking.original estimate
lookupIssues.fields.timetracking.originalEstimate
lookupIssues.fields.timetracking.original Estimate
lookupIssues.Ursprüngliche Schätzung
lookupIssues.timetracking.Ursprüngliche Schätzung
lookupIssues.estimate
lookupIssues.estimation
lookupIssues.timetracking.timespent
lookupIssues.timetracking.remainingestimate
Adding ".sum" at the end always return 0. Also I have checked the JQL. I do get data back in {{lookupIssues}} for example with {{lookupIssues.key}} or {{lookupIssues.summary}}
Version v9.12.2 Data Center
Hi Simon,
I don't think that field is currently available for Data Center. You should vote for and follow this request: https://jira.atlassian.com/browse/JIRAAUTOSERVER-877
Also, here is the current documentation showing the currently available fields:
Look under the Available properties section under Lookup Issues.
Hi @Simon Ma
As John described, the time tracking fields are not supported for the Data Center version of the Lookup Issues action yet.
Two possible workarounds for this depend upon what you want to do with the value(s):
Register now
